Hi Andy,You can use the Draw and TextSymbol classes to achieve this. Use a geometry service to find a point for placing a label inside or around the drawn polygon. You can see an example here.
<!DOCTYPE html> <html> <head>  <title>Create a Map</title>  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">  <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">  <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">  <style>    html, body, #mapDiv{      padding: 0;      margin: 0;      height: 100%;    }  </style>   <script src="http://js.arcgis.com/3.8/"></script>  <script>    var map;    require([        "esri/map",        "esri/symbols/SimpleFillSymbol",        "esri/symbols/SimpleLineSymbol",        "dojo/_base/Color",        "esri/graphic",               "esri/geometry/Polygon",               "dojo/on",        "dojo/dom",        "dojo/domReady!"    ],    function(        Map, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic,        Polygon,        on, dom    ) {      map = new Map("mapDiv", {        center: [-75.249, 38.485],        zoom: 9,        basemap: "streets"      });              on(map, "load", addGraphic);           var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,        new Color([255,0,0]), 2),new Color([255,255,0,0.25])        )           function addGraphic(){                      var singleRingPolygon = new Polygon([[-75.77, 38.45], [-75.77, 38.7], [-75.11, 38.7], [-75.11, 38.45], [-75.77, 38.45]])            var gra = new Graphic(singleRingPolygon, sfs);            map.graphics.add(gra);      }                          });  </script> </head> <body class="claro">  <div id="mapDiv"></div> </body> </html>
You will want to use the Graphic class to create the graphic and add it to your map. Ex:<!DOCTYPE html> <html> <head>  <title>Create a Map</title>  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">  <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/claro/claro.css">  <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">  <style>    html, body, #mapDiv{      padding: 0;      margin: 0;      height: 100%;    }  </style>   <script src="http://js.arcgis.com/3.8/"></script>  <script>    var map;    require([        "esri/map",        "esri/symbols/SimpleFillSymbol",        "esri/symbols/SimpleLineSymbol",        "dojo/_base/Color",        "esri/graphic",               "esri/geometry/Polygon",               "dojo/on",        "dojo/dom",        "dojo/domReady!"    ],    function(        Map, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic,        Polygon,        on, dom    ) {      map = new Map("mapDiv", {        center: [-75.249, 38.485],        zoom: 9,        basemap: "streets"      });              on(map, "load", addGraphic);           var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,        new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,        new Color([255,0,0]), 2),new Color([255,255,0,0.25])        )           function addGraphic(){                      var singleRingPolygon = new Polygon([[-75.77, 38.45], [-75.77, 38.7], [-75.11, 38.7], [-75.11, 38.45], [-75.77, 38.45]])            var gra = new Graphic(singleRingPolygon, sfs);            map.graphics.add(gra);      }                          });  </script> </head> <body class="claro">  <div id="mapDiv"></div> </body> </html>
