Get point address in popup on click
1522
09-09-2021 08:58 AM
jh9
Hi all, I'm following this tutorial and trying to implement in my code
https://totalapis.github.io/sample-code/get-started-popup/
However, when I implement, I get an error.
Uncaught TypeError: Cannot read property 'view' of undefined
Code below. Anyone know what I might be doing wrong?
<template>
  <div id="viewDiv" class="balt-theme"></div>
</template>
<script>
  /* eslint-disable */
  import { loadModules } from 'esri-loader';
  export default {
    mounted() {
      this.loadMap();
      this.getStops();
    data() {
      return {
        stops: []
    methods: {
      loadMap() {
        loadModules(['esri/config', "esri/tasks/Locator", 'esri/Map', 'esri/views/MapView', "esri/Basemap", "esri/layers/VectorTileLayer", "esri/symbols/PictureMarkerSymbol", 'esri/Graphic','esri/layers/GraphicsLayer', "dojo/domReady!"], {
            css: true
          .then(([esriConfig, Locator, Map, MapView, Basemap, VectorTileLayer, PictureMarkerSymbol, Graphic, GraphicsLayer]) => {
            // create map with the given options
          esriConfig.apiKey = "";
          var locatorTask = new Locator({
            url: "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
          // Where we add in the custom colored map
          const vectorTileLayer = new VectorTileLayer({
            portalItem: {
              id: "afff5c72b30f4102be6abe62c3591803" // ID for Map Made
          const basemap = new Basemap({
            baseLayers: [
              vectorTileLayer
          const map = new Map ({
              basemap: basemap
          // assign map to this view
          this.view = new MapView({
            container: this.$el,
            map: map,
            center: [-118.48456934438383, 34.02280292519253],
            zoom: 10,
            constraints: {
            minZoom: 23,
            maxZoom: 13
              this.view.on("click", function(event) {
        event.stopPropagation(); // overwrite default click-for-popup behavior
        // Get the coordinates of the click on the view
        var lat = Math.round(event.mapPoint.latitude * 1000) / 1000;
        var lon = Math.round(event.mapPoint.longitude * 1000) / 1000;
        this.view.popup.open({
          // Set the popup's title to the coordinates of the location
          title: "Reverse geocode: [" + lon + ", " + lat + "]",
          location: event.mapPoint // Set the location of the popup to the clicked location
        // Display the popup
        // Execute a reverse geocode using the clicked location
        locatorTask.locationToAddress(event.mapPoint).then(function(
          response) {
          // If an address is successfully found, show it in the popup's content
          this.view.popup.content = response.address;
        }).otherwise(function(err) {
          // If the promise fails and no result is found, show a generic message
            "No address was found for this location";
            // initialize graphics layer, add it to the map
            const graphicsLayer = new GraphicsLayer();
            map.add(graphicsLayer);
          this.stops.forEach((value) => {
            // using a for each function to create markers on the map for all the stops
            //Create a point
            // location
            const point = {
            type: "point",
            longitude: value[0],
            latitude: value[1]
          // const simpleMarkerSymbol = {
          //   type: "simple-marker",
          //   color: [226, 119, 40],  // Orange
          //   outline: {
          //   color: [255, 255, 255], // White
          //   width: 1
        // we are creating the components of a graphic, then adding to graphic
        // graphic is then being added to the graphics layer
        // what it actually looks like
        let symbol = {
          type: "picture-marker",  // autocasts as new PictureMarkerSymbol()
          url: "https://static.arcgis.com/images/Symbols/Shapes/BlackStarLargeB.png",
          width: "64px",
          height: "64px"
        // what is being added to the graphic layer
          const pointGraphic = new Graphic({
            geometry: point,
            symbol: symbol
          graphicsLayer.add(pointGraphic);
      async getStops() {
        // This is where we get big blue bus data initially
        let stop = await fetch(
        'http://gtfs.bigbluebus.com/parsed/stops.geojson'
        ).then(res => res.json())
        let obj = stop.features
        // pushing stops data to stops array
        obj.forEach((value) => {
         this.stops.push(value.geometry.coordinates)
</script>
<style>
  /* esri styles */
  @import url('https://js.arcgis.com/4.4/esri/themes/light/main.css');
  #app {
    font-family: Avenir, Helvetica, Arial, sans-serif;
    -webkit-font-smoothing: antialiased;
    -moz-osx-font-smoothing: grayscale;
    text-align: center;
    color: #2c3e50;
  #nav {
    padding: 30px;
  #nav a {
    font-weight: bold;
    color: #2c3e50;
  #nav a.router-link-exact-active {
    color: #42b983;
  #viewDiv {
    position: absolute;
    top: 3.5rem;
    bottom: 0;
    left: 0;
    right: 0;
</style>
ReneRubalcava
Esri Frequent Contributor
Change your anonymous "function()" methods to arrow functions "() =>{}". The context of this isn't the same inside regular functions.
You may however run into another issue. view is not in your Vue data prop. But Vue also uses JavaScript Proxy for reactive state management. This isn't compatible with our Accessor class and how we watch for property changes yet. It's on the roadmap to update in the future, but no timeline.
I have a blog post here on how to use Vue and the ArcGIS JSAPI together without Vue reactive state management.
https://odoe.net/blog/vue-jsapi-calcite
