Does anybody have a good example of filtering a layer based off of a unique id received from a click?
Kelly,
I am confused exactly what you are looking for.
What is being filtered by a click?
Are you looking for related fields?
Hi Rickey,
Let me explain my exact project. I have a map with points and a layer with the service areas of each point. I want to program it so that when the user clicks a certain point the service area for only that point pops up. Please let me know if you know of a way to do this! Thanks!
Yes, that makes more sense. Try this JS Bin - Collaborative JavaScript Debugging, it is not exactly what you are looking for. This script does what you want in reverse.
Try this code. I am not sure what you service areas are but this might work.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Select with feature layer</title> <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/tundra/tundra.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css"> <style> html, body, #mapDiv { padding: 0; margin: 0; height: 100%; } #messages{ background-color: #fff; box-shadow: 0 0 5px #888; font-size: 1.1em; max-width: 15em; padding: 0.5em; position: absolute; right: 20px; top: 20px; z-index: 40; } </style> <script src="http://js.arcgis.com/3.12/"></script> <script> var map; require([ "esri/map", "esri/layers/FeatureLayer", "esri/layers/GraphicsLayer", "esri/tasks/query", "esri/geometry/Circle", "esri/graphic", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer", "esri/config", "esri/Color", "dojo/dom", "dojo/domReady!" ], function( Map, FeatureLayer, GraphicsLayer, Query, Circle, Graphic, InfoTemplate, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer, esriConfig, Color, dom ) { map = new Map("mapDiv", { basemap: "streets", center: [-95.249, 38.954], zoom: 16, slider: true }); var censusPoints = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/1",{ infoTemplate: new InfoTemplate("Block: ${BLOCK}", "${*}"), mode: FeatureLayer.MODE_SELECTION, outFields: ["POP2000","HOUSEHOLDS","HSE_UNITS", "TRACT", "BLOCK"] }); var censusBlocks = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0"); var censusBlocksGL = new GraphicsLayer(); var bSymbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([247, 34, 101, 0.9]), 1 ), new Color([247, 34, 101, 0.3]) ); // selection symbol used to draw the selected census block points within the buffer polygon var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 12, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([247, 34, 101, 0.9]), 1 ), new Color([207, 34, 171, 0.5]) ); censusPoints.setSelectionSymbol(symbol); map.addLayers([censusPoints, censusBlocks, censusBlocksGL]); censusBlocks.on("click", function(e){ censusBlocksGL.clear(); //select point features within the clicked census block if(e.graphic && e.graphic.geometry){ var gra = new Graphic(e.graphic.geometry, bSymbol); censusBlocksGL.add(gra); var query = new Query(); query.geometry = e.graphic.geometry; censusPoints.selectFeatures(query); } }); }); </script> </head> <body> <span id="messages">Click on the map to select census block points within the group.</span> <div id="mapDiv"></div> </body> </html>
If this does not work I might be able to find more examples.
Signed in members can post, follow updates, and more. New here? Register a free account.
