FeatureTable Without Proper FeatureLayer
672
01-27-2020 05:26 AM
KarenRobine
I pulled a bunch of data to the client and have access to a FeatureSet. However, I can't build a Feature Layer as the data isn't tied to a URL (I generated the data using an SOE, so the data is a result of an analysis). In some cases, there is no corresponding geometry for the data. Is there any way to build a FeatureTable off of this table? I tried by using the original FeatureLayer (prior to analysis), and using it's Layer Definition, but so far, I've not found a way to generate a FeatureSet. It looks like it works (no errors when I create a New FeatureTable), but it's not showing up in the table at all. Thoughts?
