Feature layer created from feature set in ArcGIS JS API 4.10 does not display
6728
01-03-2019 03:29 AM
RahulMetangale2
Hi All,
I am trying to display feature layer created from featureset on map. and i am seeing following issues:
  • If "type" key is missing in gemoetry object i get following error "[esri.core.Accessor] Accessor#set Invalid property value, value needs to be one of 'esri.geometry.Extent', 'esri.geometry.Multipoint', 'esri.geometry.Point', 'esri.geometry.Polyline', 'esri.geometry.Polygon', 'esri.geometry.Mesh', or a plain object that can autocast (having .type = 'extent', 'multipoint', 'point', 'polyline', 'polygon', 'mesh')" I added type attribute like following and then this error goes away
"geometry": {
"x": -13042767.827649597,
"y": 3857692.3854717212,
"type": "point"
I know that without type key this used to work in 3.x version of API.
  • Even if i add type layer does not display on map
Here is the sample code for reference. Can someone point me to right direction.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Intro to FeatureLayer - 4.10</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.10/esri/css/main.css">
<script src="https://js.arcgis.com/4.10/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer"
function(
Map, MapView,
FeatureLayer
var map = new Map({
basemap: "streets"
var view = new MapView({
container: "viewDiv",
map: map
* Add feature layer
var citiesRenderer = {
type: "simple", // autocasts as new SimpleRenderer()
symbol: {
type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
color: "black",
outline: { // autocasts as new SimpleLineSymbol()
width: 0.5,
color: "white"
var data = {
"features": [{
"geometry": {
"type": "point"
"attributes": {
"CT_RowNo": "377",
"provider_guid": "FEE94918-9913-49FC-BABE-DB5B17111CE1",
"provider_id": 123,
"agency_name": "Agency 1",
"tenant_id": "",
"email": "First.Middle@abc.com",
"phone_no": "3044004205",
"phone_extension": "",
"license_no": 1005052
"geometry": {
"x": 5251931.8199335933,
"y": 3678761.2973740068,
"type": "point"
"attributes": {
"CT_RowNo": "378",
"provider_guid": "FEF675B1-5C09-46ED-BE06-82F053B8B953",
"provider_id": 356,
"agency_name": "New Age",
"tenant_id": "",
"phone_no": "3044004167",
"license_no": 1005014
"spatialReference": {
"wkid": 102100
"GeometryTypeEnum": 2,
"geometryType": "esriGeometryPoint",
"fieldAliases": {},
"fields": [{
"name": "CT_RowNo",
"type": "esriFieldTypeOID",
"alias": "CT_RowNo",
"length": 0
"name": "provider_guid",
"type": "esriFieldTypeString",
"alias": "provider_guid",
"length": 0
"name": "provider_id",
"type": "esriFieldTypeInteger",
"alias": "provider_id",
"length": 0
"name": "agency_name",
"alias": "agency_name",
"length": 0
"name": "tenant_id",
"alias": "tenant_id",
"length": 0
"name": "email",
"alias": "email",
"length": 0
"name": "phone_no",
"alias": "phone_no",
"length": 0
"name": "phone_extension",
"alias": "phone_extension",
"length": 0
"name": "license_no",
"alias": "license_no",
"length": 0
"displayFieldName": "CT_RowNo",
"exceededTransferLimit": false
var featureLayer = new FeatureLayer({
fields: data.fields,
objectIdField: "CT_RowNo",
geometryType: "point",
spatialReference: {
wkid: 102100
source: data.features,
renderer: citiesRenderer
map.add(featureLayer);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Rahul,
  You had an couple of issue in your code.
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/Map",
      function(
        Map, MapView,
        FeatureLayer
        var map = new Map({
          basemap: "streets"
          map: map
         * Add feature layer
          symbol: {
            color: "black",
              width: 0.5,
              color: "white"
        var data = {
          "features": [{
            "geometry": {
              "type": "point",
              "spatialReference": {wkid: 102100}
            "attributes": {
              "CT_RowNo": 377,
              "provider_id": 123,
              "tenant_id": "",
            "geometry": {
              "type": "point",
            "attributes": {
              "CT_RowNo": 378,
              "provider_id": 356,
              "tenant_id": "",
            "wkid": 102100
          "fieldAliases": {},
          "fields": [{
            "name": "CT_RowNo",
            "name": "email",
            "alias": "email"
            "name": "phone_no",
            "alias": "phone_no"
          spatialReference: {
            wkid: 102100
  </script>
</head>
<body>
</body>
</html>
1. You need to specify the spatialReference of the geometry you are creating in the json
2. Your CT_RowNo field values were a string instead of a number.
Rahul,
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/Map",
      function(
        Map, MapView,
        FeatureLayer
        var map = new Map({
          basemap: "streets"
          map: map
         * Add feature layer
          symbol: {
            color: "black",
              width: 0.5,
              color: "white"
        var data = {
          "features": [{
            "geometry": {
              "type": "point",
            "attributes": {
              "CT_RowNo": 377,
              "provider_id": 123,
              "tenant_id": "",
            "geometry": {
              "type": "point",
            "attributes": {
              "CT_RowNo": 378,
              "provider_id": 356,
              "tenant_id": "",
            "wkid": 102100
          "fieldAliases": {},
          "fields": [{
            "name": "CT_RowNo",
            "name": "email",
            "alias": "email"
            "name": "phone_no",
            "alias": "phone_no"
          spatialReference: {
            wkid: 102100
  </script>
</head>
<body>
</body>
</html>
RahulMetangale2
Thank  you Robert!
