Exclude columns in ESRI map service Query
1384
03-03-2021 03:31 AM
JayakumarPD
  Is it possible to exclude the columns in  map service query,
For Example: I have a service, with
                                       Service 1: Name, Department and ID
                                       Service 2: Name, Forest, Species and ID
                                       Service 3: Society, Asset, Culture and ID
I am calling this is a loop, when I give asterisk (*), then all columns are coming for identifier template, but I don't want ID from any service.  Is there any way.
Thankyou
JayJohnsonWashoeCounty
Clearly you can't use the * and still exclude any of the fields (ID in your case).  I think you will have to explicitly specify the fields you want returned in the query.
Jay
Washoe County GIS
JayakumarPD
Explicitly we can include but how to exclude
jcarlson
The fields are all there in the service JSON. Would it be possible to pull all the field names and then just drop 'ID' from the array before submitting it as your out_fields param?
- Josh Carlson
Kendall County GIS
JayakumarPD
is it possible to share code snippet or any reference link
