ESRI JS API Sample: Viewshed broken
1962
12-08-2020 02:19 AM
NicolasGIS
Honored Contributor
Hello JS API team,
Just noticed that viewshed samples are broken in 3.X and 4.X:
https://developers.arcgis.com/javascript/latest/sample-code/geoprocessing-viewshed/index.html
https://developers.arcgis.com/javascript/3/samples/gp_viewshed/
The following error is logged in the console:
Error executing tool. Viewshed :
You must enter at least ONE observer point↵↵Failed to execute (Viewshed).↵Failed to execute (Viewshed).↵Failed to execute (Viewshed)
Cheers
KenBuja
Are you still getting that error? I'm not seeing it on either sample in Chrome, Firefox, or Edge.
KenBuja
NicolasGIS
Honored Contributor
Indeed, it is solved !
LibertadChapinal
The solution is down and also the sample codes, have you got any example working?
