Create a New FeatureLayer with new polylines creates from a Query in a point layer (jscript 3.24)
2253
07-10-2021 06:03 PM
GeoGarage-vmbp-
Hello. I'm developing with JS 2D API 3.24 in WAB 2.8.
I'm trying to make a New FeatureLayer which is compound of polylines making from point geometries as result of a Query against a FeatureLayer in my server. This runs ok an if I create a GraphicsLayer and adds it to my map, I can see the graphics correctly.
The problem begins when I try to create a FeatureLayer with this geometries. I receive the next message in the javascript console (as info in blue (chrome) and not as error):
esri.layers.FeatureLayer: unable to find '[object Object],[object Object],[object Object]' field in the layer 'fields' information [url: ]
There are 3 '[object Object]' because I'm defining 3 fields in featureCollectionObject.fields. There is strikingly a reference to a "layer fields information".
This is the code for creating the featureLayer:
_crearLayerVectores: function(graficos){
        var featureCollectionObject = {
          layerDefinition:{
            geometryType: "esriGeometryPolyline",
            objectIdField:"OBJECTID",
            fields:[{
              name: "OBJECTID", alias: "OBJECTID", type: "esriFieldTypeOID"
              name: "FechaFrom", alias: "FechaFrom", type: "esriFieldTypeDate"
              name: "FechaTo", alias: "FechaTo", type: "esriFieldTypeDate"
          featureset:{
            features: [graficos],
        var featureLayerOptions = {
          mode: FeatureLayer.MODE_SNAPSHOT,
          outFields:[featureCollectionObject.layerDefinition.fields]
        var vectores = new FeatureLayer(featureCollectionObject, featureLayerOptions);
        vectores.title = this.nls.nombreCapaGenerada + this._campo + " = " + this._discriminador;
        var sLineSymbol = this._obtenerSimpleLineSymbol();
        var renderer = new SimpleRenderer(sLineSymbol);
        vectores.setRenderer(renderer);
        this.map.addLayer(vectores);
To improve understanding of code, the graphics are generated like this:
padre = this;
queryTask.execute(query, function(results){
            for(i = 0; i < results.features.length - 1; i++){
              var puntoFrom = results.features[i];
              var puntoTo = results.features[i+1];
              var geomPolyLine = new Polyline(capa.spatialReference);
              geomPolyLine.addPath([[puntoFrom.x, puntoFrom.y],[puntoTo.x, puntoTo.y]]);
              var atributos ={};
              atributos["OBJECTID"] = i + 520;
              atributos["FechaFrom"] = puntoFrom.attributes[padre._campoFecha];
              atributos["FechaTo"] = puntoTo.attributes[padre._campoFecha];
              var graficoVector = new Graphic({
                geometry:geomPolyLine,
                attributes: atributos
              graficosVectores.push(graficoVector);
            padre._crearLayerVectores(graficosVectores);
            //padre._crearGraphicLayerVectores(graficosVectores); --> runs ok
I have also tried this. It doesn't give any warning or error in the javascript console, but it doesn't draw anything.
Differences:
In featureCollection.featureSet.features set to [] (empty array) (line 5)
Graphics are entered with: featureLayer.applyEdits() (line 34)
Following this: Create a feature layer based on a feature collection example
        var featureCollection ={
          "layerDefinition": null,
          "featureSet":{
            "features": [],
            "geometryType": "esriGeometryPolyline"
        featureCollection.layerDefinition = {
          "geometryType": "esriGeometryPolyline",
          "objectIdField":"OBJECTID",
          "fields":[{
            "name": "OBJECTID", "alias": "OBJECTID", "type": "esriFieldTypeOID"
            "name": "FechaFrom", "alias": "FechaFrom", "type": "esriFieldTypeInteger"
            "name": "FechaTo", "alias": "FechaTo", "type": "esriFieldTypeInteger"
        var vectores = new FeatureLayer(featureCollection, {
          id: this.nls.nombreCapaGenerada + this._campo + " = " + this._discriminador
        vectores.applyEdits(graficos, null, null);
        this.jimuButtonBorrarCapas.style.visibility = "visible";
I hope that someone will can help me.
Best regards.
The universe is a hostile place
BraulioCordova
I hope this can help you. It's with feature layer with grahics layer I found limitations
var trazorutapol=new FeatureLayer({
        fields: [
            alias: "ObjectID",
            type: "oid"
            alias: "ubigeo",
            type: "string"
            alias: "placa",
            type: "string"
        title: "Ruta de vehiculo",
        objectIdField: "ObjectID",
        geometryType: "polyline",
        spatialReference: { wkid: 4326 },
        renderer: {
          type: "simple",  // autocasts as new SimpleRenderer()
          symbol: {
            type: "simple-line"// autocasts as SimpleLineSymbol()
            color: "#E47F19",
            width: 3
var featurepol = [];
for (var i = 0i < data.lengthi++)
featurepol.push(new Graphic({
                        geometry: {
                          type: "polyline",  // autocasts as new Polyline()
                            paths: [
                              [data[i].longitud,data[i].latitud],
                              [data[i+1].longitud,data[i+1].latitud]
                        attributes: {
                          ubigeo: data[i].ubigeo,
                          imei: data[i].imei,
                          placa: data[i].placa
trazorutapol.source = featurepol;
map.add(trazorutapol);
GeoGarage-vmbp-
Hello. First of all, thank you for your reply.
Whern you say:
I don't sure if I'm understanding you: The code wich you have posted is functional for you with FeatureLayer but you have problems with GraphicsLayer?.
If is that correct, I can help you with GraphicLayer.
This is the way in which I make the GraphicsLayer: "graficos" is an array of esri/Graphic
 _crearGraphicLayerVectores: function(graficos){
        var vectoresGraphicsLayer = new GraphicsLayer();
        vectoresGraphicsLayer.title = this.nls.nombreCapaGenerada + this._capasGeneradas.length;
        this.map.addLayer(vectoresGraphicsLayer);
        this._capasGeneradas.push(vectoresGraphicsLayer);
        for(i=0; i < graficos.length; i++){
          graficos[i].setSymbol(sLineSymbol);
          vectoresGraphicsLayer.add(graficos[i]);
        var extent = GraphicsUtils.graphicsExtent(graficos);
        this.map.setExtent(extent.expand(1.20));
