CORS error
11493
07-22-2021 05:02 AM
ChitraKrishnan
I copied the sample code from https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=layers-featurelayer-shap... to my local and it works fine for drp_county_boundary.zip.
But when I try to upload tl_2020_39_tabblock20.zip which I downloaded from https://www.census.gov/geographies/mapping-files/time-series/geo/tiger-line-file.html  it throws below CORS error.
Index:1 Access to fetch at 'https://www.arcgis.com/sharing/rest/content/features/generate?filetype=shapefile&publishParameters=%...' from origin 'http://localhost' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource. If an opaque response serves your needs, set the request's mode to 'no-cors' to fetch the resource with CORS disabled.
1. Can't we directly work with the local copy of the downloaded shape files without adding to arcgisonline?
2. I did add to arcgisonline and getting the same CORS error - https://utility.arcgis.com/usrsvcs/servers/4b648ef9586c487b948f37e3ea4c5453/rest/services/tl_2020_39...
Thanks
Chitra
3 Solutions
Sage
Hi Chitra,
I believe the shapefile you are trying to add has too many features and the CORS error you are seeing is a bit misleading.  I downloaded the shapefile and it has 276,428 individual features.  The sample in the params object has a maximum of 1000 features defined and is set to enforce maximum file sizes.
const params = {
     targetSR: view.spatialReference,
     maxRecordCount: 1000,
     enforceInputFileSizeLimit: true,
     enforceOutputJsonSizeLimit: true
 I'm not sure why the debugger is throwing a CORS error, but when I downloaded the tiger shapefile and exported just a handful of the features to a new shapefile, zipped up the result and added it from my local hard drive with the sample code it seemed to work as expected.
Sage
Do you have access to ArcGIS Pro or ArcMap desktop software?  If so there are lots of different ways to go about it but probably the easiest would be to make an interactive selection, or selecting by attributes and then export the selected records as a new shapefile by right clicking on the original shapefile in the table of contents selecting 'Data' in the drop down and then export features.  Only the selected features will export.  To export to a shapefile select the folder you want to export to in the dialog and give it a name
https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/select-features-interactively.htm
https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/select-features-using-attributes.ht...
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/export-data.htm
You could also clip the original shapefile if you have another a separate shapefile that represents your area of interest.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/clip.htm
If you don't have access to ESRI's desktop software it won't be as easy but its still possible with python and and geopandas to do a clip.
https://geopandas.org/gallery/plot_clip.html
There are lots of other ways as well like using QGIS or some other geospatial software, but the process should be similar.  Creating a selection and exporting or clipping.
ChitraKrishnan
Thank you!!! Let me try.
Thanks
Chitra
Sage
Hi Chitra,
const params = {
ChitraKrishnan
Thank you very much for the reply.
I am actually new to Esri. how can I export only the required features to a new shapefile? Can you please share some link to understand this?
Thanks again
Chitra
Sage
ChitraKrishnan
Thanks
Chitra
RachelGomez
To get rid of a CORS error, you can download a browser extension like CORS Unblock. The extension appends Access-Control-Allow-Origin: * to every HTTP response when it is enabled. It can also add custom Access-Control-Allow-Origin and Access-Control-Allow-Methods headers to the responses.
Greeting,
Rachel Gomez
