Coordinate Widget and localStorage - is it configurable?
7337
12-14-2020 09:04 AM
yuruiology
Hi - I've noticed that the Coordinate Widget uses localStorage to save its state - however, for some reason it uses the current path as part of the `key`. This is causing a problem for us because the url in our app changes very often, as a result, the widget is creating tons of records in localStorage very quickly.
Is this behavior configurable? Is it possible to either make it use a fixed key, or store the state in `sessionStorage` instead? (at least the records will be cleared after the session ends).
Thanks!
Noah-Sager
Hi @yuruiology, we have an update to share. The widget has been updated to make use of sessionStorage. This will be available at the next release (4.20), in late June or early July.
Noah-Sager
Hi yuruiology, thanks for posting here. Unfortunately, I don't know of a workaround for this issue at this time. However, this sounds like a valid enhancement for the CoordinateConversion widget. We will consider this for a future release, and I'll update this thread when we get something installed.
yuruiology
I see, thanks! please keep us posted.
Noah-Sager
yuruiology
Awesome, thank you!
