Change font for Popup Fields
3175
04-12-2021 06:08 AM
Vakhtang_Zubiashvili
Hi Guys,
I am using API 4.18, I need to change Font in Popup, I need to use my local font. I could do it for API 4.13 using CSS, but now it stops working. How can I do this now?
Kind regards,
Vakhtang
Noah-Sager
Hi @Vakhtang_Zubiashvili, it's tough to say without seeing how you did it at 4.13, but my hunch is that the HTML sanitizer (which we introduced at 4.14) is the issue here:
https://developers.arcgis.com/javascript/latest/4.14/#breaking-changes
If this is the case, the alternative solution would be to use custom functions. Here is a blog post that details the issue and the workaround:
https://www.esri.com/arcgis-blog/products/js-api-arcgis/mapping/using-html-with-popups-in-the-arcgis...
If this doesn't work for you, can you share some more details? I'd like to see how you are trying to do it at 4.18 (which worked at 4.13). A sample app on someplace like Codepen would be great.
Dear Noah,
Thank you for response, for 4.12 (or 4.14 I do not remember exactly) I used CSS code like this to change font style in Popup:
      .esri-widget__table {
             font-family: HKolkhetyMtav; /* ფონტის შეცვლა popup-ში */
and it worked.
Now as you told me I tried something like this:
      welltemplate = {
                              title: "Well",
                              content: '<i style="font-family:Garamond;font-size:16px"> xxxxx</i>'
but no success.
What to do I do not know 😞
UndralBatsukh
You
Hi there,
You should set the style on html elements like div, p, span etc.
The following will work for example:
var template = {
   // autocasts as new PopupTemplate()
   title: "{NAME} in {COUNTY}",
   content: '<div  style="font-family:Garamond;font-size:26px"><i>content</i></div>'
Dear @UndralBatsukh
Thank you for replay.
It works, but only for Font Size, Font Color etc. But not for Font Style. Font Style remains default Sans-Serif...
Code Template:
welltemplate = {
      title: "Well",
      content: "<div style='font-family:HKolkhetyMtav;font-size:26px;color:red'><li> Hello Guys</li></div>"
I use local font for my native language ( It is Georgian), here is CSS for it:
@font-face {
  font-family'HKolkhetyMtav';
  srcurl('./fonts/hkolkhetymtav.ttf'format('embedded-opentype'), /* Internet Explorer */
  url('./fonts/hkolkhetymtav.ttf'format('woff2'), /* Super Modern Browsers */
  url('./fonts/hkolkhetymtav.ttf'format('woff'), /* Pretty Modern Browsers */
  url('./fonts/hkolkhetymtav.ttf')  format('truetype'), /* Safari, Android, iOS */
  url('./fonts/hkolkhetymtav.ttf'format('svg'); /* Legacy iOS */
If i change font style in browser for <li> it works fine ( I have changed default FONT  into Georgian FONT ("Hello Guys" is translated as "ცელოო ჩუყს"), see pics please:
No one can help me 😞
