build a simple web map
2445
11-14-2021 02:39 AM
eyalj
hello
I'm trying to build my first application that uses arcgis maps in react and I'm trying to display a webmap
but when I render the map its looks like im doing something wrong
that's my code:
import React, { useEffect, useRef } from "react"
import WebMap from "@arcgis/core/WebMap"
import MapView from '@arcgis/core/views/MapView';
function App() {
  const mapDiv = useRef()
  useEffect(()=>{
    if(mapDiv.current){
      const webmap = new WebMap({
        portalItem:{
      const view = new MapView({
        map: webmap
      view.container= mapDiv.current
  return(
    <div id ='map' ref={mapDiv}
    ></div>
export default App;
Kishore
@eyalj I don't see any error from your code. I think you are missing the Map div height and width. try following in the return will show you the map:
return (
    <div id='map' ref={mapDiv} style={{ height: "100vh", width: "100vh" }}
    ></div>
Regards,
Kishore
shaylavi
Have you initialised the API with a token? I suggest you try to follow the basic tutorial from the documentations -
https://developers.arcgis.com/javascript/latest/display-a-map/
Shay
Kishore
return (
    ></div>
Regards,
Kishore
eyalj
Thanks! @Kishore It works
eyalj
