Avoid login popup when showing FeatureLayer
1400
05-02-2017 04:02 AM
ScaiConsulting
Hi everyone,
I want to avoid the popup login (username and password) when I try to show a FeatureLayer from client side (javascript).
You can see the popup in the screenshot attached on this post.
What I've accomplished so far:
- Created a FeatureLayer from ArcMap Desktop and published it on my Organization Rest Services. I got a link for retrieve that. It is hosted on ArcgisOnline.
- Connected my Web Application to my esri online server and got a token (through client and secret id ) to access this feature layer
- On client side, in Javascript, I created a FeatureLayer from the complete uri (FeatureLayer Uri + token), and added this layer to the map showed by the MapView item. But surprisingly to me, I got a popup to login with my ArcgisOnline credentials.
It is possible to simply avoid the login popup? Why is not "enough"  to attach a token (which, in theory, has to give me access for that FeatureLayer published on my organization) to the FeatureLayer rest uri?
Thanks in advance
popup
jkumartry1980
Did you got solution for this?, I am facing similar issue. Kindly share the solution if you resolve this issue.
Thanks in advance.
K.Jayakumar
sharathgh
I hope you're good. Even I'm facing this, wanted to know if have find any solution for this yet. Please share , would be great helpful.
Sharath Gh
