ArcGIS JS 4 SAML auth
2018
04-24-2020 01:46 AM
VictorTey
Hi, I have been following the sample
Access ArcGIS Online items using OAuthentication - 4.15
and i kept getting a invalid redirect_uri.
I have done the following
  • Add item -> application -> application
  • Register info
  • Add my machine uri to the redirect_uri under registered info
  • I have share this app to my organisation
my code
can someone please advise what have i done wrong?
var info = new OAuthInfo({
                // Swap this ID out with registered application ID
                appId: "c13v2Nuys97mUArm",
                // Uncomment the next line and update if using your own portal
                //portalUrl: "",
                // Uncomment the next line to prevent the user's signed in state from being shared with other apps on the same domain with the same authNamespace value.
                authNamespace: "portal_oauth_inline",
                popup: true
            IdentityManager.registerOAuthInfos([info]);
IdentityManager.getCredential(info.portalUrl + "/sharing")
            .then(function(){
                const map = new Map({
                    basemap: "hybrid",
                    layers: [layers]
                const view = new MapView({
                    container: "viewDiv",
                    map: map,
                    center: [116, -32],
                    zoom: 10,
                    popup: {
                        autoOpenEnabled: true
 //do whatever else
Tags (3)
DerrickWong
Hi Victor Tey
When you add  your machine uri to the redirect_uri under registered info for the application, did you include the full path?
e.g https://domain.com/xxx/xxx/xxx.html instead of just https:domain.com
Regards,
Derrick
DerrickWong
Hi Victor Tey
Regards,
Derrick
VictorTey
Spot on. Thank you Derrick Wong
