ArcgIS Javascript API 4.12 TimeSlider widget
1096
07-04-2019 03:24 AM
ChristopheSuter
I am trying to use the new TimeSlider widget in "cumulative-from-start" mode. As it works fine in "time-window" mode, in "cumulative-from-start" mode the slider does not update when playing. Did anyone encounter the same problem ?
DavidWilson3
Hi Christophe,
Did you include a fullTimeExtent with a start and end date?
ChristopheSuter
Hi David,
Yes I did, the slider works in "cumulative-from-end" mode but not in "cumulative-from-start" mode, the slider is blocked when playing.
See my layer (hosted feature layer) configuration below, and its url is
https://services1.arcgis.com/TRedWbwyW3ioV38C/ArcGIS/rest/services/VOIE_VERTE_FL_CS/FeatureServer/0
Best,
Christophe
