Adding different info Templates for each point of multipoint
1036
10-28-2020 10:54 PM
SHARVARIKANGUTKAR
Hello,
I tried the solution posted in Programmatically adding multiple points to the map  this thread. It is plotting multiple points on a map programmatically. There is one common info Template text assigned for all points. The solution worked fine for me, but I wanted to know if there is any way I can add different info Templates for each point.
Thank you
