4.9 Search Widget using suggest instead of findAddressCandidates to find suggestions
1488
12-03-2018 05:54 AM
ShakilChoudhury
The locator I'm using supports "findAddressCandidates" but the search widget uses "suggest" as the default method to the locator when retrieving search suggestions. How can I change it so it uses "findAddressCandidates"?
RobertScheitlin__GISP
ShakilChoudhury
Hi Robert, I'd like suggestions to be enabled but to use the "findAddressCandidates" method instead of the "suggest" method as "suggest" returns "Endpoint not found." Is this possible?
No that is not possible.
