3D callout line doesn't work with client-side graphics:
3292
8
12-04-2017 08:47 AM
mingleidi
Does anyone try to use callout line with client-side graphics?
I followed this example: https://developers.arcgis.com/javascript/latest/sample-code/visualization-point-styles/index.html
this example use a feature layer from url: "http://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/LyonPointsOfInterest/FeatureServer".
but it doesn't work with a feature layer which creates client-side graphics based on data returned from a web service.
Is there a limitation on 3d callout line?
here's my code snippet:
1. create a feature layer based on layer definition:
featureLayer = new FeatureLayer({
fields: this.layerDefinition.fields,
objectIdField: this.layerDefinition.objectIdField,
geometryType: this.layerDefinition.geometryType,
2. set elevation and feature reduction and renderer:
featureLayer.elevationInfo = {
// elevation mode that will place points on top of the buildings or other SceneLayer 3D objects
mode: "relative-to-scene"
// feature reduction is set to selection because our scene contains too many points and they overlap
featureLayer.featureReduction = {
type: "selection"
featureLayer.renderer = this._getUniqueValueRenderer() as any as Renderer// callout render
3. here the renderer code:
_getUniqueValueRenderer() {
let verticalOffset = { // verticalOffset shifts the symbol vertically
screenLength: 150, // callout line length
maxWorldLength: 200,
minWorldLength: 35
uniqueValueRenderer = {
type: "unique-value", // autocasts as new UniqueValueRenderer()
field: "AQHI",
uniqueValueInfos: [{
value: 1,
symbol: this._get3DCallOutSymbol(verticalOffset, "Museum.png", "#D13470")
value: 2,
symbol: this._get3DCallOutSymbol(verticalOffset, "Restaurant.png", "#F97C5A")
value: 3,
symbol: this._get3DCallOutSymbol(verticalOffset, "Church.png", "#884614")
value: 4,
symbol: this._get3DCallOutSymbol(verticalOffset, "Hotel.png", "#56B2D6")
value: 5,
symbol: this._get3DCallOutSymbol(verticalOffset, "Park.png", "#40C2B4")
value: 6,
value: 7,
symbol: this._get3DCallOutSymbol(verticalOffset, "beer.png", "#F97C5A")
value: 8,
symbol: this._get3DCallOutSymbol(verticalOffset, "senate.png", "#884614")
value: 9,
value: 10,
return uniqueValueRenderer;
_get3DCallOutSymbol(verticalOffset: any, iconName: string, color: string) {
return {
type: "point-3d", // autocasts as new PointSymbol3D()
symbolLayers: [{
type: "icon", // autocasts as new IconSymbol3DLayer()
resource: {
href: this.iconPath + iconName
outline: {
color: "white",
verticalOffset: verticalOffset,
callout: {
type: "line", // autocasts as new LineCallout3D()
color: "white",
border: {
color: color
4.set source to an array of graphics, generated based web service data
featureLayer.source = graphics;
Thanks.
Tags (1)
ThomasSolow
My sample uses a renderer to assign a symbol to each graphic.  I can change it so that the symbols are set manually on each graphic and it still works:
https://codepen.io/solowt/pen/LOadjd?editors=1000#0
ThomasSolow
I've successfully used callouts with client-side graphics.
Can you post a simple code sample?
mingleidi
Thanks Thomas, here's my code snippet:
type: "selection"
minWorldLength: 35
field: "AQHI",
value: 1,
value: 2,
value: 3,
value: 4,
value: 5,
value: 6,
value: 7,
value: 8,
value: 9,
value: 10,
return {
symbolLayers: [{
resource: {
outline: {
color: "white",
callout: {
color: "white",
border: {
color: color
ThomasSolow
I'm not sure what's wrong here, but here's a simple sample that creates a feature layer in the client from an array of randomly generated graphics and symbolizes them with symbols that have callouts: https://codepen.io/solowt/pen/LOadjd?editors=1000#0
One thing to take a look at is verticalOffset.  If you're zoomed out and have a maxWorldLength of 200, it's quite possible you won't be able to notice the callouts.  It may be better to just use screenLength sometimes.
mingleidi
Thank you Thomas, I will check that sample, and screenLength.
mingleidi
and Thomas, if possible, could you please post your code here too?
mingleidi
Hi Thomas, Based on your example I made callout showing now, the only issue is when assigning symbol to the graphic, the callout is disappeared. In your example the graphic doesn't have a symbol, can you try to assign a symbol to see if callout shows up?
Benjamin
ThomasSolow
mingleidi
Thanks Thomas, it's resolved, I think I mess up with graphic symbol and render, should only need one, either graphic symbol or render, but not both.
