Services are not getting loaded
6640
17
09-05-2013 11:49 PM
MohammedIsmail
hi
I got stuck since last two month on this issue
like my problem is, services are not getting loaded when i browse my site
(all the services has to be get loaded in a drop down list)
u can try this link http://maps.icrisat.org/bhochetana
i have uploaded my web application on IIS
my domain name is Maps.icrisat.org
My server name is gisserver
My service URLs are like this
http://gisserver/ArcGis/rest/service...ron/MapServer/
i have also defined cross domain
<?xml version="1.0" ?>
- <cross-domain-policy>
<allow-access-from domain="www.maps.icrisat.org/bhochetana" ports="80"/>
<allow-access-from domain="*.maps.icrisat.org/bhochetana" to-ports="80"/>
<allow-access-from domain="10.3.1.160" to-ports="80" />
<allow-access-from domain="GISSERVER.ICRISAT.CGIARAD.ORG" />
<allow-http-request-headers-from domain="*.maps.icrisat.org/bhochetana" headers="*" />
</cross-domain-policy>
what could be the reason if you could tell me i can check
Ismail
RobertScheitlin__GISP
Ismail,
   Your app is still not getting the crossdomain.xml file. Right now if you look at the HTTP traffic in Fiddler your app is requesting the crossdomain.xml from http://gis/crossdomain.xml. You need that file in the wwwroot folder on your web server.
It is also failing on http://maps.icrisat.org/bhochetana/assets/Icrlogo.jpg, and http://maps.icrisat.org/bhochetana/assets/Movie.flv
MohammedIsmail
hi
i have created crossdomain.xml but still am facing the same problem
Crossdomain.xml
  <allow-access-from domain="maps.icrisat.org/bhochetana" ports="80"/>
  <allow-http-request-headers-from domain="maps.icrisat.org/bhochetana" headers="*" />
What should i do please help me
Thanks & Regards
Ismail,
   You should probably make the crossdomain.xml less restrictive untill you get it to work. Where did you put that crossdomain.xml?
https://developers.arcgis.com/en/flex/guide/using-crossdomain-xml.htm
DasaPaddock
I found the policy file at http://maps.icrisat.org/crossdomain.xml but it's not well formed.
Try:
<?xml version="1.0"?>
    <allow-access-from domain="10.3.1.160" to-ports="80"/>
    <allow-http-request-headers-from domain="maps.icrisat.org/bhochetana" headers="*"/>
DasaPaddock
The file also needs to match the cross-domain policy file specification.
Try:
    <allow-access-from domain="maps.icrisat.org"/>
    <allow-access-from domain="*.maps.icrisat.org"/>
    <allow-access-from domain="10.3.1.160"/>
    <allow-http-request-headers-from domain="maps.icrisat.org" headers="*"/>
MohammedIsmail
hi Robert
I have copied crossdoman file in C:\Inetpub\wwwroot folder of my server
is my crossdomain file is not correct please let me know
thanks
Ismail,
   Your application is still trying to use a crossdomain.xml from
Normally this means that you have a layer in your map that is using a similar URL. You need to make sure that your map is only using URLs that contain the fully qualified URL like: http://maps.icrisat.org/etc/etc
MohammedIsmail
hi
Thanks alot  Robert and dasa its working now
you can also check
