Search widget  (<linkfield></linkfield>) question
3458
10
04-13-2011 11:17 AM
JerryBiedenbender
How do I get the Linkfield in the search widget to work?
<configuration>
<layers>
  <layer>
   <name> Stream Gage </name>
   <url>http://rmgsc.cr.usgs.gov/ArcGIS/rest/services/nhss_usdata/MapServer/0</url>
   <expression>STAID = '[value]'</expression>
   <textsearchlabel>Search by Station ID  [ Example: 03260100 ]:</textsearchlabel>
   <graphicalsearchlabel>Drag a box to identify the Stream Gage</graphicalsearchlabel>
   <fields>STAID, STANAME, STAGE, TIME,URL, CLASS</fields>
   <titlefield>Stream Gages</titlefield>
  </layer>
</layers>
<zoomscale>5000</zoomscale>
</configuration>
RobertScheitlin__GISP
Jerry,
   Have you tried adding you URL field there?
JerryBiedenbender
Yes sir, but it seems to try to open up a link from my system instead of following the actual link, I get the following error. (Cannot find 'file:///C:/Documents%20and%20Settings/jbiedenbender/desktop/WebMaps/Flex/Flex_Projects/Final_Web-Apps/SD1/bin-debug/URL'.   Make sure the path or internet address is correct)
Once I publish the app on my server I get the same error but directed towards the holding folder that its in on there.
Jerry
Jerry,
Does your config look like this:
<layer>
<linkfield>URL</linkfield>
</layer>
JerryBiedenbender
<?xml version="1.0" ?>
// Copyright © 2008 - 2009 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/FlexViewer/License.txt
<configuration>
 <layers>
  <layer>
  </layer>
 </layers>
</configuration>
Jerry,
   Which Version of the Flex Viewer are we talking about?
JerryBiedenbender
I believe I grabbed this code from 1.3
Jerry,
   Not sure what you are doing wrong then as I just tested it using Sample Flex Viewer 1.3 using:
<layer>
   <fields>STAID,STANAME,STAGE,TIME,URL,CLASS</fields>
  </layer>
And it worked fine. The only change I made was removing the spaces in between the field names and the commas.
JerryBiedenbender
Do you think it might have something to do with my mxml file?
Jerry,
    Yep,   You definitely changed a line in the code that wasn't suppose to be changed.
Line 396 in the StreamGages.mxml is suppose to be:
link = value;
