Navigation Tool Decoupled from the Flex Viewer and DrawTool
1563
7
08-06-2012 01:18 PM
ionarawilson1
I downloaded the navigation tool decoupled from the flex viewer by Rober Sheitlin and it looks great on my application. However I have a draw tool and when I draw a polygon after I click on the zoom in button it creates a red boundary around the polygon and zooms in usually to another area. How can I deactivate the navigation toolbar (especially the zoom in, zoom out tools) when I am using a drawing tool? I have tried everything I could and nothing works. Please help!
Thank you!
Here is the link to the thread I downloaded the file (I used the version for the 2.3 API)
http://forums.arcgis.com/threads/24250-Something-I-m-still-a-little-confused-about
RobertScheitlin__GISP
Ionara,
   I have not play with that in a very long time but it should be as simple as you setting the NavigationWidget map attribute to null when you activate your drawtool and back to the map on your tools draw finish.
ionarawilson1
Robert, I tried that and it did not work
Here is how my navigation widget is defined in my main app:
<navigation:NavigationWidget  left="12" top="20"  id="navigationwidget"   />
So everytime I activate the drawtool I had
navigationwidget.map = "";
and when I deactivated the drawtool I had
navigationwidget.map = myMap;
But I got this run-time error:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at com.esri.Navigation::Navigation/changeNavigation()
at com.esri.Navigation::Navigation/doNavAction()
at com.esri.Navigation::Navigation/buttonbar1_valueCommitHandler()
at com.esri.Navigation::Navigation/__btnBar_valueCommit()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/dispatchEvent()
at spark.components.supportClasses::ListBase/commitSelection()
at spark.components.supportClasses::ListBase/commitProperties()
at spark.components.supportClasses::ButtonBarBase/commitProperties()
at mx.core::UIComponent/validateProperties()
at mx.managers::LayoutManager/validateProperties()
at mx.managers::LayoutManager/doPhasedInstantiation()
at mx.managers::LayoutManager/doPhasedInstantiationCallback()
Thanks for any help you can provide!
ionarawilson1
Now I added the myMap to:
<navigation:NavigationWidget  left="12" top="20"  id="navigationwidget" map="{myMap}"  />
And I get this error when I click on the buttons for the draw tools:
TypeError: Error #1034: Type Coercion failed: cannot convert " " to com.esri.ags.Map.
at one_searchonequery_plusgraphicsearch_onlyfreehand/ClickHandler()
at one_searchonequery_plusgraphicsearch_onlyfreehand/__freehandbutton_click()
Ironara,
   That is because "" is a string and you can not set the map that the navigation widget is expecting to a string you need to set it to a null value...
navigationwidget.map = null;
ionarawilson1
Now I get thisrun-time error when I deactivate the drawtool and mouse over the map to go use the zoom tool
at com.esri.Navigation::Navigation/map_rollOverHandler()
Ionara,
   And you are sure you set the Navigation widgets map back to an instance of the map as I mentioned in my earlier post, on draw tool deactivate?..
ionarawilson1
I believe so. I am attaching the code, do you think you can take a look to make sure I am doing this right?
Thanks
