map.units support in agslib-3.0pre-2012-03-15
1266
12
04-15-2012 08:40 PM
TomSchuller
Occasional Contributor III
Hy,
I just wanted to migrate some widgets to the FlexViewer3.0.
Unfortantly, I'm blocked by the property "units" in the "Map" class.
In the "What's new" and "Migrating 2.5 to 3.0", I dont' find anything about a change on that property:
  http://resourcesbeta.arcgis.com/en/help/flex-api/concepts/index.html#/What_s_new_in_ArcGIS_API_for_F...
  http://resourcesbeta.arcgis.com/en/help/flex-api/concepts/index.html#/Migrating_from_2_5_to_3_0/017p...
In the API reference, I don't find a description for units:
http://resourcesbeta.arcgis.com/en/help/flex-api/apiref/com/esri/ags/Map.html#units
On the other side, reading the doc of the scale property, there is a relation to "units":
http://resourcesbeta.arcgis.com/en/help/flex-api/apiref/com/esri/ags/Map.html#scale
Is this a bug of a missed property or an undocumented change in the 3.0 api.
Tom
IvanBespalov
Tom,
yes "units" property is not in reference (I do not know why), but it is String type property and it exists:
units property
units:String
The units of the Map.
These units are used for calculating the map scale. The default value is the units of the first layer added to the map.
This property can be used as the source for data binding.
map.units = Units.METERS;
see com.esri.ags.Units
TomSchuller
It's not only missed in the reference, it's also missed in the library itself.
I can't use:
map.units
in my code.
Tom
IvanBespalov
:confused:
[ATTACH=CONFIG]13541[/ATTACH]
test:
protected function onWidgetOpen(event:Event):void
    Alert.show("Map units are: '" + map.units + "'", "onWidgetOpen");
[ATTACH=CONFIG]13542[/ATTACH]
No comments.
TomSchuller
I'm on agslib-3.0pre-2012-03-15
Your version is on: beta1 2011-12-16
Tom
IvanBespalov
Tom, you're right. I did not pay attention to it.
IvanBespalov
Map units are the first loaded layer units.
Until ESRI developers complete reference (or fix bugs), you can use first layer units:
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      xmlns:esri="http://www.esri.com/2008/ags">
 <s:layout>
  <s:VerticalLayout />
 </s:layout>
 <fx:Script>
  <![CDATA[
   import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
   import com.esri.ags.layers.Layer;
   import mx.collections.ArrayCollection;
   import mx.controls.Alert;
   protected function button1_clickHandler(event:MouseEvent):void
    var layer:Layer = getMapFirstLayer();
    if (layer != null)
     var message:String = "";
     if (layer is ArcGISTiledMapServiceLayer)
      message = "Map units are: '" + ArcGISTiledMapServiceLayer(layer).units + "' - the first loaded layer units";
     else if (layer is ArcGISDynamicMapServiceLayer)
      message = "Map units are: '" + ArcGISDynamicMapServiceLayer(layer).units + "' - the first loaded layer units";
     Alert.show(message, "Map units");
   private function getMapFirstLayer():Layer
    if (map != null)
     var mapLayers:ArrayCollection = map.layers as ArrayCollection;
     if (mapLayers != null && mapLayers.length > 0)
      return mapLayers.getItemAt(0) as Layer;
    return null;
 </fx:Script>
 <s:Button label="Show map units" click="button1_clickHandler(event)" />
 <esri:Map id="map">
  <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/>
 </esri:Map>
</s:Application>
BjornSvensson
It's a yet-to-be documented change in the 3.0 API. Thanks for reminding us 🙂
We removed it because you no longer need to set it.  Based on the spatial reference, the API will now automatically figure out the units for you.
TomSchuller
Bjorn,
i agree that it's not important to set that property.
But I think it's useful to read out the information, either as:
  • readonly map property like: map.units
  • or readonly spatialreference property like: map.spatialReference.units
The spatialReference class has currently also no-property defined to read it out:
http://resourcesbeta.arcgis.com/en/help/flex-api/apiref/com/esri/ags/SpatialReference.html
I hope you can re-implement it in your API or give some way to access it.
If it will not be exposed as property, I will have to create a lookup-table for each spatialReferece-wkid.
Tom
BjornSvensson
Hi Tom,
I'm curious - what do you use it for?  Just to display it to end user (seems a little unnecessary) - or do you need it for something else?
