<esri:Map id="map"> <esri:extent> <esri:Extent xmin="-60884403.02" ymin="657021.19" xmax="45425778.42" ymax="12202069.94" spatialReference="{new SpatialReference(102113)}"/> </esri:extent> <esri:ArcGISTiledMapServiceLayer url="http://DOMAIN/ArcGIS/rest/services/SERVICE/MapServer" /> </esri:Map>
Thanks rscheitlin,I find that the level does work. I also thought that my extent was completely being ignored, but I found that it was not being ignored, but because I was trying to take advantage of the wrapAround180 feature in the new API to show the entire extent of the US, I was using an extent that didn't make sense. I was using the expanded view of the world, zooming in and reading the map.extent to get the extent I wanted to use. It didn't even occur to me that the extent I was using was gibberish. There seems to be a bug with the wrap feature that keeps subtracting (or adding) as the map is scrolled past the dateline. Thanks for your help. Everything is working okay now. I think some work needs to be done on the wrap feature before it's ready for me to use. Thanks again!
Signed in members can post, follow updates, and more. New here? Register a free account.
