(EDIT: FYI using 3.0 preview)I am using a custom Symbol in a GraphicsLayer with a infoWindowRenderer defined which does nothing but display some static stuff (from the InfoWindow sample) but I'm seeing some strange results. When I click on a symbol, it looks like either the first symbol in the GraphicsLayer or perhaps all of the symbols are getting re-drawn under where the infoWindow appears. Here is a picture before and after clicking on a symbol:[ATTACH=CONFIG]13790[/ATTACH][ATTACH=CONFIG]13791[/ATTACH]When I click the 'x' on the infoWindow, the extra added symbol(s) goes away.Here is what my graphicsLayer definition looks like:<esri:GraphicsLayer id="markersLayer" infoWindowRenderer="com.flack.geni.display.mapping.mapproviders.esriprovider.testInfoWindow" />
I'm not doing much with the infoWindowRenderer, here's the code for that:<?xml version="1.0" encoding="utf-8"?> <esri:LabelDataRenderer xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <esri:label>test</esri:label> <s:BorderContainer backgroundColor="white" borderColor="black" color="green" cornerRadius="5" minHeight="0" minWidth="0"> <s:layout> <s:VerticalLayout paddingBottom="5" paddingLeft="5" paddingRight="5" paddingTop="5"/> </s:layout> <s:Label text="Sex ratio"/> <s:Label text="Divorce rate:" toolTip="Divorce rate is the number of divorces per 1000 people."/> </s:BorderContainer> </esri:LabelDataRenderer>
Any insight would be greatly appreciated 🙂
