I can't hide the ESRI LOGO with the property logoVisible.
759
05-29-2010 04:39 AM
__1
I used the API V1.3 to develop my application,and i hava set the  property logoVisible="false",but the logo doesn't hide.
What's the reason?
RobertScheitlin__GISP
jmuguy,
    You can not hide the logo using the logoVisible= "false" property if the only data you have in your map is data from esri's servers. If you have at least one map service for a source other than esri than that property works. You can also look at this thread for an alternative solution.
http://forums.esri.com/Thread.asp?c=158&f=2421&t=287497&mc=35#msgid894479
__1
Thank you for your help.Now,i can hide the logo.
