How to stop the wheel event propagation
14329
12
12-24-2011 10:46 PM
GennadyOster
Hi !
I have the flex application (actually, the modified flex viewer) shown inside the iframe on the other page.
When I use wheel to zoom in/out, and the outer page has scroll bar - the wheel event bubbles to this outer page and it is scrolled.
I'd like to disable the wheel event propagation when the mouse pointer is over map.
Is there simple conventional way to do it ?
Thanks in advance.
Regards,
Gennady
IvanBespalov
fix it
private function init():void
   initWheelEvents();
if not success, please show your code (ViewerContainer.mxml as it is)
UPD - working application
JohanMeijer
Hi Ivan,
Really like the Live train map! Any chance you share some tips on how it works, live updates on AGS services? 🙂
Thanks for the fix, that did it! No more scrolling at http://www.pbl.nl/en/roadsfromrio/trends-in-biodiversity-loss. I thought I had tried it, but browsercaching is also terrible here when debugging flex/flash applications...
To get it to work I also had to add:
init();
to the
private function creationCompleteHandler():void
This is loaded at creationComplete (see s:application at the top of the mxml)
Johan
IvanBespalov
Find
C:\Users\User Name\mm.cfg (if file doesn't exist create it)
How to change flash player debugger configuration file
