How to stop the wheel event propagation
14805
12
12-24-2011 10:46 PM
GennadyOster
Hi !
I have the flex application (actually, the modified flex viewer) shown inside the iframe on the other page.
When I use wheel to zoom in/out, and the outer page has scroll bar - the wheel event bubbles to this outer page and it is scrolled.
I'd like to disable the wheel event propagation when the mouse pointer is over map.
Is there simple conventional way to do it ?
Thanks in advance.
Regards,
Gennady
RobertScheitlin__GISP
Gennady,
   Have you tried
evt.preventDefault();
                evt.stopImmediatePropagation();
GennadyOster
Hi Robert !
Thank you very much for your help,  and sorry for delay.
I tried to play with wheel event and reached the 50% of success 🙂 : now I can switch off the wheel action on the map, but I still cannot do it for the browser window.
I played with the event listener parameters (priority, event phase) with no success.
Here is what I did in the index.mxml of the Flex viewer:
<s:Application .........
       creationComplete="init();">
  private function init() : void{
   mapManager.map.addEventListener(MouseEvent.MOUSE_WHEEL,onMouseWheel,false,0);
  private function onMouseWheel(evt:MouseEvent):void{
   evt.stopPropagation();
Am I doing something wrong ?
Thanks.
Regards,
Gennady
P.S. I've used the stopImmediatePropagation too with the same result. Gena
Gennady,
   To prevent the default browser scrolling requires some Googling and custom JavaScript code as that really has nothing to do with flex.
http://stackoverflow.com/questions/2005339/disable-mouse-wheel-scrolling-while-cursor-over-flex-app
GennadyOster
Hi Robert!
Thanks. I'll give it a try.
Sure I googled before posting to the forum, but missed this post somehow.
Regards,
Gennady
DasaPaddock
GennadyOster
Thanks, Dasa !
I've already used the mousewheeltrap solution. For me it has two great advantages: (i) I don't need to deal with "the host Party", 'cause the whole solution is inside Flex application, and (ii) I don't need to deal with dojo.
Nevertheless - thank you very much for your attention and help.
Regards,
Gennady
IvanBespalov
Gennady, may be this code is not better solution but it works without JS.
1 - We just added MouseWheel.as in to workspace as it is.
2 - in FlexViewer -> ViewerContainer.mxml added:
// inside ViewerContainer.mxml <Script> tag
 * Listen creation complete handler
private function init():
   initWheelEvents();
 * Init mouse wheel events listeners
protected function initWheelEvents():void
    if (mapManager && mapManager.map)
        mapManager.map.addEventListener(MouseEvent.ROLL_OVER, mouseWheelOver);
 mapManager.map.addEventListener(MouseEvent.ROLL_OUT, mouseWheelOut);
 * mouse wheel out handler
protected function mouseWheelOut(event:MouseEvent):void
    MouseWheel.release();
 * mouse wheel over handler
protected function mouseWheelOver(event:MouseEvent):void
    MouseWheel.capture();
GennadyOster
Hi Ivan !
Thanks. I'll give it a try a little bit later - even if not to implement, but at least to learn what and how you did it.
Regards,
Gennady
JohanMeijer
Hi Ivan,
I somehow can't get this to work...? We are using flexviewer 2.4 and I want to disable scrolling for instance here:
http://www.pbl.nl/en/roadsfromrio/trends-in-biodiversity-loss
* So you put the MouseWheel.as in it's own place under com.ru.etcs.ui
* import it in the viewercontainer.mxml
* put the code from your message in the script (for instance: under the import?)
For some reason I get errors on "expecting an identifier before the left bracket" at the init() function?
Thanks for any help!
Johan
