how to add new item on the menu option in the attribute table?
5117
6
07-24-2014 11:35 AM
marcostenorio
Como adicionar um novo item no menu opção do widget tabela de attibute?
I'm trying to add an option to export to excel.
Eu estou tentando adicionar uma opção para exportar para o Excel.
I already have the api as3xls and function, but do not know where to insert.
Tenho a api as3xls e a função pronta, mas não sei onde inserir.
someone could indicate which file mxml I change?
Alguém poderia indicar qual arquivo mxml devo alterar?
thank you very much.
Muito obrigado.
Tenorio
BjornSvensson
The relevant code for that is not in the Flex Viewer source code.  The AttributeTable is an API component and the source code for that is part of the API download.
Inside the zip file, you might want to start looking at
ArcGIS_Flex\src\com\esri\ags\skins\supportClasses\AttributeTableOptionsMenu.mxml
and other Attribute* files in ArcGIS_Flex\src\com\esri\ags\skins\
marcostenorio
Thank you. I had seen this alternative. insert the button. but was unable to call the function. also was unable to understand the role that exports to csv.
which is sent to this event? heareth and perform the export?
private function exportGroup_clickHandler(event:MouseEvent):void
                dispatchEvent(new Event(EXPORT_TO_CSV));
                remove();
marcostenorio
to where the event is sent?
who listen and perform the export?
                remove();
BjornSvensson
It's the AttributeTable API component that listens and performs the export.
marcostenorio
Jorn, I made the changes listed below, but does not call the function. could help me identify what is missing?
public static const EXPORT_TO_XLS:String = "exportToExcel";
private function exportGroup2_clickHandler(event:MouseEvent):void
                        dispatchEvent(new Event(EXPORT_TO_XLS));
                        remove();
</s:HGroup>
            <s:HGroup id="exportGroup2"
                          width="100%"
                          buttonMode="true"
click="exportGroup2_clickHandler(event)"
                          verticalAlign="middle">
                  <s:Image width="16" source="@Embed('../../../../../assets/skins/SelectRelatedRecords16.png')"/>
                  <s:Label width="100%"
                              maxDisplayedLines="1"
                              rollOut="label_rollOutHandler(event)"
                              rollOver="label_rollOverHandler(event)"
                              showTruncationTip="true"
                              text="{resourceManager.getString('ESRIMessages', 'exportToExcel')}"/>
AttributeTableWidget
public function exportToExcel(event:MouseEvent):void
                        var dd:Array = new Array ();
            dd= layersUsedInAttributeTable;
                        var sheet:Sheet = new Sheet();
                        var xls:ExcelFile = new ExcelFile();
            xls.sheets.addItem(dd);
                        var bytes: ByteArray = xls.saveToByteArray();
                        var fr:FileReference = new FileReference();
            fr.save(bytes,"ExportExcel.xls");
marcostenorio
I tried to use the same logic in existing code
