Flex 3.1 Related Tables Security Problem
2753
03-12-2013 10:03 AM
AnthonyNguyen1
I am using Flex 3.1 with a related table to show where project boards are located throughout our campus. The site is protected by a proxy and token system, which authenticates and grabs a token every time someone goes to the site. The problem I am having is that every time I click on "Show related records," it prompts me to put in additional username and password (as well as say that the password will be sent unencrypted).
If I turn security off for the service in ArcGIS Server Manager (for 10.1), I do not get the sign in issue.
Also note, that this issue happens for other services that I try to secure.
Thanks in advance for any help.
SarthakDatt
This issue has been fixed for the next release(3.2)
AnthonyNguyen1
Do you have a time frame when 3.2 will be released? Will it be in the next quarterly release, which I believe is sometime in April?
GISDev1
By Mar. 31. You can check GitHub for a lot of the upgrades already being shown.
