Editor do all features in the mxd have to be in SDE database
775
07-07-2011 12:39 PM
ShawnKraft
Is it okay to have some layers in shapefile and the ones I want to be edited in SDE?  I mean, will it work if set up that way?
BjornSvensson
The Editor works with layers from a Feature Service.  The Feature Service requires SDE.  So, "no", you can't edit shapefiles using the Editor.
ShawnKraft
In my mxd I have several layers that are shapefiles and one that is an SDE feature dataset.  The problem I am having is I have everything set up but when I go to ArcGIS Server Manager to enable the feature access for my service, it won't start it because it says 30 layers are non-SDE.
ShawnKraft
Okay well then what are the prerequisites for setting up the Editor?
