Edit Widget - layers show in build but not when post to web
3635
17
01-18-2012 03:58 PM
by Anonymous User
Not applicable
Original User: gtuchristina
I have a list of feature services that display when I am in Flash builder, but not when I post them to the web?  I am stuck.  I have been working on this for some time.  I would greatly appreciate any suggestions.
ChristinaMcCullough
I have hit success.  I am running two cloud instances and on one of the servers there was a < missing from the crossdomain.xml file.  Even though the data was not coming from that server, It was giving me fits.  thanks once again for all your help.
RobertScheitlin__GISP
Christina,
   If you were to use a tool like fiddler than you would likely see that it will be a crossdomain.xml issue. It could be something else but this is the first thing I would suspect. Fiddler is free and pretty easy to figure out.
by Anonymous User
Not applicable
I did see there was an issue with the crossdomain.XML file, but I am not sure why.  The cross domain.xml file is written to be open "*"?  I will be moving the site to 2.4 soon. I am going to try something and if I cannot figure it out, I will respond back in this post.  Thanks.
Christina,Do you have the crossdomain.xml on your ArcGIS Server?
by Anonymous User
Not applicable
I have the crossdomain.xml file in the wwwroot folder.
?xml version="1.0"?>
<!DOCTYPE cross-domain-policy SYSTEM "http://www.adobe.com/xml/dtds/cross-domain-policy.dtd">
<cross-domain-policy>
    <site-control permitted-cross-domain-policies="all"/>
    <allow-access-from domain="*"/>
</cross-domain-policy>
Christina,
   So your web server and your ArcGIS Server are on the same machine? I could take a look if you give me the address.
by Anonymous User
Not applicable
We have two sites on the cloud.  We would have to have a WebEx.  Or, I can just wait until I move them to 2.4 which I plan to do within the next two weeks.
BjornSvensson
FYI - just upgrading your application to 2.4 or 2.5 will not change anything in regards to crossdomain issues.  The requirements for crossdomain.xml is the same for all Flex applications.
by Anonymous User
Not applicable
My crossdomain.xml file sits in the inetpub/wwwroot folder.  I am not clearly understanding why this may be an issue.  Could you elaborate?  Please.  The web server and the ArcGIS Server are on the same machine.
Christina,
   So does your crossdomain.xml file appear in the browser when you enter http://yourServer/crossdomain.xml?
