Clusters 'flare in' unexpectedly when using info window
1424
03-04-2011 11:36 AM
patrickb
I have some code based off of the FeatureLayer/Clustering sample for the Flex API. Like the sample, I want to show an info window when the user clicks one of the graphics in a cluster (i.e. I handle FlareMouseEvent.FLARE_CLICK).
Just like in the sample, I have noticed that my code works great for the most part. However, it seems that clicking 'certain graphics' on 'some clusters' causes the cluster to 'flare in' unexpectedly (i.e. the cluster closes when I do not expect it to).
Because this happens only sometimes, I am at a loss how to fix the problem. Has anyone seen this behavior? If yes, were you able to work around this little annoyance?
I have attached an image showing the Flex API sample, and a cluster that is particularly troublesome (on my computer at least).
Patrick
