Cluster PictureMarkerSymbol
1415
6
03-22-2011 07:00 AM
Drew
Anyone know if you can cluster PictureMarkerSymbols?
I am able to cluster using the FlareSymbol, but the PictureMarkerSymbol  does not work.
Here is what I would like to do, but I am afraid this is not supported.
<esri:PictureMarkerSymbol id="markerSymbol" source="images/star.png" height="25" width="25"/>
<esri:WeightedClusterer id="clusterer" symbol="{markerSymbol}"/>
According to the docs the WeightedClusterer.symbol property accepts any com.esri.ags.symbols
Thoughts?
Drew
DasaPaddock
Yes, that should work. The cluster would be represented by the star. What's happening when you try this?
Drew
I am just seeing a single star and no clustering. The star is positioned on the map as a cluster, but when i mouseover nothing seems to happen.
I will try and post some sample code when I am back at my desk.
Drew
DasaPaddock
It's actually working as expected. The cluster is turned into a single Graphic and it's being drawn using the given symbol. Any other behavior depends on the symbol that is used.
Drew
Makes sense now.. For some reason I thought it would flair too.. But I guess that's what a FlareSymbol is for : ) doh!
I guess what I am looking for is a FlarePictureMarkerSymbol, but that does not yet exist.
Thanks for your help.
Drew
RobertScheitlin__GISP
Drew
Drew,
  Actually it does.
http://thunderheadxpler.blogspot.com/2010/08/image-flare-symbol-for-clustered.html
Awsome!
Thanks for the assistance guys!
