"POWERED BY ESRI " Logo removal
2643
5
09-24-2012 09:12 AM
SonaliVishwakarma
Hi
Is there a way to replace the "Powered By ESRI" logo which appears at the right corner of the screen?
I have been looking at the solutions posted previously in the older forums but I am not able to remove the logo.Can some one please guide me correctly ?
Sonali
AnthonyGiles
Honored Contributor
Sonali,
There is an attribute called logoVisible which can be set to true or false:
http://help.arcgis.com/en/webapi/flex/apiref/index.html
Regards
Anthony
SonaliVishwakarma
Anthony
I tried doing that but it was not helping.
In the "MapManager.mxml" file I changed
map.logoVisible=true to
map.logoVisible=false.
Can you suggest some other way?
Is it somewhere related with the dynamic or tiled map services? I am not using ESRI's services and therfore i am still doubtful why the logo is still coming. I am not able to get what is missing.
Sonali
AnthonyGiles
Honored Contributor
Sonali,
You say you have tried changing things in the mapmanager.mxml does this mean you are using the sample flex viewer and not just creating your own app using the API? If so in your main configuration file use esrilogovisible="false" in the map tag, see:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Main_configuration_file/01m30000001800...
Viewer questions should be posted to the viewer forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
Regards
Anthony
SonaliVishwakarma
Anthony,
Thanks a lot!!!!!!
Regards
Sonali
AnthonyGiles
Honored Contributor
Sonali,
Please don't forget to mark the post as answered by checking on the tick on the thread that was most helpful.
Regards
Anthony
