Access of undefined property field
3571
7
04-27-2012 05:18 AM
RobertScheitlin__GISP
I am using the 2.5 API and UniqueValueRenderer and the attribute property has been depreciated in lieu of the field property but in Flash Builder 4.6 I get this orange question mark for several properties in the 2.5 API... This is not a warning or an error and does not cause an issue building, but it is just a nuisance. Does anyone have any advice?
[ATTACH=CONFIG]13878[/ATTACH]
[ATTACH=CONFIG]13879[/ATTACH]
DasaPaddock
Can you also try removing the swc, letting it show a bunch of errors, and then adding it back?
by Anonymous User
Not applicable
Original User: dpaddock
Have you tried running Project -> Clean?
Dasa,
   Yep I did that and then shut down and restarted Flash Builder and they were gone for a few seconds until I did a autocomplete code in the project and after that they reappeared.
by Anonymous User
Not applicable
Can you double check that you only have the 2.5 swc in your library path?
DasaPaddock
by Anonymous User
Not applicable
Original User: rscheitlin
Dasa,
  It turn out that it was these offending libs:
FlexProjections-2.3.1-6.30.11.swc
FlexProjections.swc
XGeom.swc
import com.esri.ags.geod
import com.esri.ags.grat
Thanks for pointing me in the right directon
stevemclaughlin
I've upgraded from Flex Builder 4.5 to Flash builder 4.6, and I'm getting errors on
XGeom.swc, saying I need to recompile it in SDK4.6,
is the source code available?  or is an updated swc available?
thanks,
steve
Dasa,
FlexProjections.swc
XGeom.swc
by Anonymous User
Not applicable
Original User: rmcfarlane
Have you looked here: https://github.com/Esri/public-safety-cop/tree/master/libs
