2.4 PopUp scrollbar bug
9513
25
08-04-2011 03:59 PM
DasaPaddock
A bug has been found in the 2.4 release where if you have many fields shown and the scrollbar appears in the PopUp, it only works the first time the PopUp opens. The second time it opens, only the title is shown. The field area is blank. The fix for this is in the attached PopUpRendererSkin.
Here's more information about how to use "custom" skins:
http://help.arcgis.com/en/webapi/flex/help/index.html#/Styling_and_skinning_overview/017p0000001s000...
Tags (1)
KevinHigh
Ari-
For my <description>, I just use one long line of code with <br> tags between each new line:
 <description><![CDATA[Bluff Level: {BluffLevel}<br>Failure Date: {FailureDate}<br>Description: {Description}<br>Elevation: {Elevation} ft<br>USACE Reach: {USACE_Reach}<br>Image: <a href="http://gisweb:9231/bluffexplorer/bluff_photos/bluff_failure/{Picture}.jpg"><u>{Picture}</u></a>]]></description>
This works perfectly for me. See the attached picture for the example
EDIT: The code above is supposed to be one long line, but somehow got wrapped when I posted it.
GregoryPierce
Adding to what Jay said:
Once you copy the PopUpRenderSkin.mxml into the com.esri.viewer.skins folder
add the following to the defaults.css file in  src->default package
esri|PopUpRenderer
skinClass:ClassReference("com.esri.viewer.skins.PopUpRendererSkin")
compile the project and run
Subu
Thank you!  I thought I was going crazy trying to figure out how to implement that skin!
GrayRackley
Code:
<description><![CDATA[Bluff Level: {BluffLevel}<br>Failure Date: {FailureDate}<br>Description: {Description}<br>Elevation: {Elevation} ft<br>USACE Reach: {USACE_Reach}<br>Image: <a href="http://gisweb:9231/bluffexplorer/bluff_photos/bluff_failure/{Picture}.jpg"><u>{Picture}</u></a>]]></description>This works perfectly for me. See the attached picture for the example
This is a quick workaround.
MeghanMcGaffin
After banging my head for some time now this workaround has fixed my issue!  Many many thanks!
KevinHigh
Is this fixed in 2.5?
RobertScheitlin__GISP
