I am not able to see my created Las-Dataset File?
2691
14
10-12-2018 02:33 AM
tobiashog
New Contributor II
Hey there,
I created a LAS-Dataset File with my LAS Input Data. I runned it succesfully. But if I want to see the Data in the Scene there is no data. Can someone help me?
David
by Esri Contributor
Something simple to try: the LiDAR data may be appearing in a place you didn't expect it. Try to right-click on your new lasd layer in the Contents Pane and choose Zoom To Layer.
tobiashog
New Contributor II
Thank you for your help. I tried this already. The only thing i can see is a "white paper". Furthermore i imported the data with the right coordinate system.
George_Thompson
Esri Notable Contributor
So I looked at the file and there is no spatial reference information. What is the coordinate system of this file?
I think that you get that corrected and it will start to work for you.
--- George T.
tobiashog
New Contributor II
The coordinate System is 31467. Does it work at your computer now?
George_Thompson
Still no luck for me. I would contact the vendor of the LAS file and have them help.
--- George T.
