Free converter for IFC/Revit to SLPK?
3369
01-13-2022 12:32 AM
vipapril
Hi All,
We are trying to become the BIM Viewer training provider for Hong Kong CIC (Construction Industry Council).
This training course requires a free software to view BIM files.
We would like to know if there is a way to convert IFC or Revit into scene layer package without using ArcGIS Pro.
Please kindly suggest.
Thank you,
April
SimonSchütte_ct
MVP Regular Contributor
The format specification can be found here: https://github.com/Esri/i3s-spec / https://docs.opengeospatial.org/cs/17-014r8/17-014r8.html
There is also a converter, but it can only convert slpks into different formats: https://github.com/Esri/i3s-spec/tree/master/i3s_converter
FME Supports the conversion: https://www.safe.com/integrate/esri-indexed-3d-scene-layer/ - other tools probably as well (I found this one for example: https://loaders.gl/modules/tile-converter/docs/cli-reference/tile-converter ).
vipapril
Thanks for the information.
Seems there is no free conversion tool for IFC/Revit to SLPK.
Micah-Callough
This workflow currently requires ArcGIS Pro. Now since the I3S is an open standard you could in theory write your own converter if you were so inclined.
SimonSchütte_ct
It looks like it is supported now by the latest version of this tool: https://loaders.gl/modules/tile-converter/docs/cli-reference/tile-converter
