In my survey I have a series of quesitons that repeat, how do I auto-fill them after the time the questions have been asked and I still need to be able to change the answer(s) as I go through the survey.
718
07-21-2019 07:17 PM
ToddAckerman
I am collecting points along a trail and at each point, there will be 5 questions asked about the trail, I would like to have the survey auto-fill after the first time inputting answers and have it continue doing so as I go down the trail and collection points.
by Anonymous User
Not applicable
Hi Todd,
Yes this should be possible using calculations or defaults. What do you want to "auto-fill" the questions with? Where will the value be populated from? For example a field in the parent layer or the first repeat record or a static value that doesn't change?
Depending on the workflow and where you get the values from to "auto-fill", will depend the best way to set up a calculation to achieve the functionality you are after.
Phil.
ToddAckerman
Hi Phil,
Guessing you can tell by the question I am new at this and learning a lot.  So to answer your question, I would say from the first repeat.  An example would be starting at the trailhead and the width of the trial is 30 inches, I go down the trail 25 feet and collect another point and the trail width is still 30 inches, so I am hoping I would not have to reenter this value again. But, as I go down the trail the width changes to 20 inches and so I collect another point and change the width to 20 inches and am hoping his number (20) would remain until I change it again.
I hope this helps you in helping me.
Thank you again,
Todd
by Anonymous User
Not applicable
Hi Todd,
Yes, you can do this with repeats and new records. You will need to use a hidden question outside of the repeat to store the last value that was entered into that question in the repeat record, and then set a calculation to use this value when a new repeat record is added. It is a little tricky to configure, but others users such as Doug Browning‌ and Mike Bruening have done this and similar complex expressions with repeats successfully and posted about it.
Phil.
