How to turn off the authorization of working offline
2085
12-30-2021 03:49 AM
JianyiLiu
I mis-click the authorize ArcGIS pro to work offline, and now I'd like to login my account on another PC, which is refused as I authorized the offline mode. Is there any solution?
JianyiLiu
Thanks for your advice, I have fixed this problem by the solution from https://support.esri.com/en/technical-article/000014443
DanPatterson
You need to undo the changes on the original machine... or get someone to do it for you.
If that is not possible, you will have to contact Tech Support
... sort of retired...
JianyiLiu
