Text-Based Instant App Templates: Nearby and Zone Lookup
721
11-19-2025 12:46 PM
Labels (2)
CatherineWendland
This year (2025) I attended the Esri User Conference and my main mission was to inquire with all the product teams about their accessibility roadmaps. The Instant Apps team pointed out a couple of templates that allow you to hide the map and essentially have a text-only application, run by a map in the background.
Hiding the map removes a major accessibility visual barrier and can make your content potentially more screen-reader compatible.
Instant App Templates with the ability to hide the map:
  • "Nearby" allows the users to see what features are near their location or a certain address.
"Zone Lookup" allows the users to look up if their location or an address is within a polygon.
Tips for using these templates as a text-only application:
  • Turn off Express Mode. This will allow you to see all settings.
  • Configure the map pop-up. The information returned to the user is what is contained in the pop-up. If you are intending to use this as a screen reader-friendly application, make sure the pop-up is configured to contain only text that is understandable to the end-user.
    • Use dynamic text to populate plain language sentences that give the user the intended information of the application.
    • If you include charts or images, include alt-text in the HTML settings.
    • If your pop-up is text-heavy, use nested heading levels to break up the content.
  • Hide Map in the settings
    • In the "Nearby" template this setting is found in Nearby > Search Method > Hide Map
    • In the "Zone Lookup" template, this setting is found in Theme & Layout > Layout > Hide Map
    • In the "Nearby" template, you must "Search by Radius"
      • Find this setting in Nearby > Search Method > Search Method > Search Radius
Zone Lookup - hide the mapZone Lookup - hide the map
Nearby Template - hide the mapNearby Template - hide the map
