georeferencing "Cad Data" with arcmap 10.3.1
1263
11-04-2016 09:50 AM
RobertoTantari
hi,
good evening to all,
i've a problem when try out to georeference cad data with arcmap 10.3.1.
an esri error suddenly appears and the program quickly closes when i click add-control point on cad layer
thanks everybody for responses
bob
RobertoTantari
up!
DanPatterson_Retired
for vector data, you should be using About spatial adjustment—Help | ArcGIS for Desktop
AbdullahAnter
Honored Contributor
Is your CAD data hasn't spatial reference ?
You can define projection for CAD Data if it has true coordinates, just Export data to Shape file then define projection.
if the CAD data without true coordinates you can make spatial adjustment after export CAD to SHP.
RobertoTantari
It was a program's bug
I installed the patch and now all is OK
Many thanks for yours quickly replies
Bob
