Trying to import a revit file to ArcGIS Pro and Validate Position Grayed Out
1005
04-26-2024 08:54 AM
HGuzman
Hello, I'm trying to import these Revit files into ArcGIS Pro. They all have unknown coordinate system projections, meaning I need to assign them a coordinate system, first I need to Validate position, but that tab will not show any Current Status like it should, it is just blank. Has anyone had this problem before? Does anyone have a solution to this? Thanks!
ArushiMathur
Were you able to figure this out? I am facing the similar challenge I am unable to correctly locate my Revit import on GIS the model is floating on ocean. I made sure to set up correct base coordinates in Revit and in GIS too. Can you someone help?
