Slope map created from tin Symobology. Slope is in degree or Percentage
989
03-05-2011 08:30 AM
pramodmishra
Hi need to find out, the slope that is created from the symbology tab option is in degree or percentage. Does anybody know about that?
thanks
Tags (1)
PatrickTaurman
Degrees.  If you check out the range of values it's 0-90.  Per the Help:
The range of slope values in degrees is 0 to 90. For percent rise, the range is 0 for near infinity. A flat surface is 0 percent, a 45 degree surface is 100 percent, and as the surface becomes more vertical, the percent rise becomes increasingly larger.
Web Help for Slope
