Setting Minimum and Maximum Values in a Raster
2144
09-30-2010 03:22 AM
MattPowell
I want to be able to minus a value from a raster (using Raster Math) but to not go below a certain value. For example: I have a raster ranging from 0.2 to 8 and I want to minus 1, but for the values that would be -0.8 to become 0.
I have tried using the Output Z domains in the Environment Settings of raster Math, but to no avail.
Any suggestions?
Regards
Matt
EricRice
Esri Alum
Matt,
One way to get the answer is to do the subtraction like you normall would.  Then use a Con statement to say anything below your threshold should be equal to the threshold; if it's above the threshold, keep the value as-is.  In your example the threshold is 0.  Would this work for you?
Eric
DonovanCameron
Matt,
Eric
Output = Con(Input, 0, Input, "Value < 0")
MattPowell
Thanks guys, I'll give this a go.
