Load 3D arcgis Map from a file?
988
10-07-2022 07:49 AM
LuisKaiser
Hello all,
I want to load a arcgis 3d map from a file, because I have to use my unity application offline.
For example I know that I can use in Esri "2D" a mmpk file, maybe there is something similar in Esri 3D
Do you know if it is possible and which file type is used?
My last question ist where I find this files?
Thanks for your help!
Andrew--Johnson
The 3D equivalent of a mobile map package is a mobile scene package. I'm not sure if Unity supports a (.mspk) but if it does you create them in ArcGIS Pro using the GP tool
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/create-mobile-scene-package....
thanks,
Andrew
