This is odd and I have no idea why it is happening. ARCmap 10.3 and ArcScene
Normally when I use the Line of sight after constructing the sight lines, the given result is straight lines, with the attribute "VisCode" dividing what is visible and not. The inputs are the sight lines, the dtm and a polygon feature class with the buildings.
Yesterday I tried to do a Line of sight:
input surface - DSM.img
input line features - sight_lines
input features - <empty>
output - into a GDB
the result is a line with the "viscode" attribute but that follows all the relief of the DSM in that direction. better explained:
- the profile of the first line, it is a straight line from the start point to the end point
- the profile of the second, it is an irregular line depicting all the obstructions of the relief from the starting point to the end point.
what happen?!
cheers
P
