Hillshade/Slope analysis and Z Factors
4279
09-26-2012 05:49 AM
DanielErklauer
Hello,
I have a question about z factors and how to use them within a slope analysis and hillshade function.  I have a data set that is XYZ.  X and Y are in decimal degrees while z is in meters.  I understand that the z value has to be converted to degrees using a z factor of .00001 (as per ESRI Help hillshade Spatial Analyst).  What I am confused about is in the help manual under Hill shade 3D analyst another z factor chart is offered based on latitude (I believe this is due to the geoid ????).  Then when I read the Slope help (both spatial analyst and 3d analyst) z values are not offered so do I use a value of .00001 or is it lat dependent?
Can someone please explain this or recommend an article to read on this?
Thank you
Tags (1)
MarcinGasior
This article explains how to use z-factor and how it depends on latitude:
http://blogs.esri.com/esri/arcgis/2007/06/12/setting-the-z-factor-parameter-correctly/
Despite the factors presented in this article, for cartographic purposes a bit higher z-factor in Hillshade tool gives more vivid terrain picture.
MarcinGasior
DanielErklauer
Thanks that is what I was looking for.
