Extracting a From-Z and a To-Z for a road network from a DEM
619
05-04-2023 07:25 AM
JWest1
Using ArcGIS Pro 2.9.5.
I have a DEM and road polylines that I need to extract the From and To-Z values. I have extracted points from the segment ends and imported the Z values into those points but need to be able to add those to the polylines in their appropriate place. Unfortunately, unless I manually look at each line I do not have any way to differentiate the attribute of a from or to point value on those lines.
Is there a tool or workflow that can:
  1. Create a From and To field in a point feature class to extract a Z value from a DEM or other elevation data
  2. Append or join the From and To Z value from the point feature into a polyline feature
  3. Automate this process?
Tags (3)
