Hello Dan, Thanks for your reply. I am using share/export. I have tried all the file types, and so far, none are rendering good results, except for the .svg file type, which looks the best, even adequate, but I can't open it with our graphic software (We use Corel Draw).
I've tried different settings in the export to pdf Export Option dialog box. I've exported with different compression types, and at different dpi. From the defaults, changing them ect. increasing the dpi, so far, no good exports apart from the svg file.
Any suggestions? There must be a way to export a scene without it getting vectorized?
marie
